is there a specific reason you want that case. it looks rly nice. but if you want a tv tuner. id suggest that you get a cheaper case (not a complete crap one though) and spend the money you saved on a new tuner. haupauge seems to be one of the better brands and a highly suggested one. with the tuner tehre are also programs. which allow you to turn it into a dvr so you could record rewind pause shows on tv. if you want to you could also look into a hi def tuner. if you have hd satelite or cable you could then have hi def on ur computer besides whats on it already and the internet.
feel free to pm me if you have any more questions.
edit. do you already have ram for this?
and do you have an operating system for this?
also after reading more into ur post. if u have a hi def tv tuner you could record hi def. (ill def look more into this myself cuz im curious myself and could better answer ur questions
Originally Posted by Greg121986 ![]() Right around this time of year I find something that I want, and throw money at it. ![]() I currently have a 15 foot HDMI cable that I use in rare cases to hook up to the TV which is in the next room. I use audio through my regular PC 2.1 speakers which will eventually be hooked up with a very long audio cable. I thought it would be easier/a more fun idea to build an HTPC. But I'm not sure if I would really use it to its full potential. I thought I would move all of my music and movies to the HTPC. But, I still want to keep my 2TB drives in my main PC. This will raise the cost significantly, though. I also want to be able to stream from Hulu and possibly NetFlix while using my HTPC. I will also use it as a DVD player, and I might get a Blu Ray drive, but I don't know for sure. I want to get a PS3 in the very near future as well. Will the PS3 allow me to view things like Hulu? Can I get to the video on my PC from the PS3 attached to the network? I do not have HD DirecTV, though. And if I build an HTPC I probably won't be able to get the HD receiver I need to have a basic HD package. They want $99 for the HD receiver and I really do not want to pay that to begin with. Would I even be able to record the HD shows from the DirecTV receiver if I had an HTPC? Here is what I came up with so far. I would like to buy as many used pieces as possible. But I am set on this case unless someone can point me onto another one. Lian Li Case $139.99 Gigabyte 785G $79.99 Athlon II 250 3.0Ghz $67.99 Corsair 400W PSU $49.99 WD 1TB Caviar Green $84.99 I would really like the 1.5TB Green, but they are out of stock right now. One or two would be fine for now. Total: $422.95 Is there anything else? I would really like a TV tuner, but it is pretty expensive. I also do not have an HD antenna so I can't use that to get HD signals. Basically the only source I have for HD entertainment is what I have on my HDD right now and the internet. |
