1 - 7 of 7 Posts
Is there a way I can connect my consoles on my pc or on my monitor ?<br />
i'm tired of my tv, I want to get a wide screen monitor to play with my consoles on, my tv is old, so instead of buying a new tv, i'll get a good monitor.
yes you can.. just get a vga converter box for it.. what consoles are you talking about.. xbox 360 makes a vga adapter .. for the others im pretty sure you will need to get a converter box that will let you plug in the rca or even coax into and then output it to your moniter
Emulate is your other option...
Discussion Starter #4
I don't think i'll be able to emulate the Ps3...<br><br>
my tv is outdated...<br><br>
all in wonder gfx card ??
Filthy Casual
PS3 should have a VGA box you can get, like the 360 and XBox both do. I'll get better resolution on this monitor than I could on ANY HDTV on the market right now...<br><br>
Hooray for $300 LCDs <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
just get a tv card with composite in
1 - 7 of 7 Posts
