Control panel : How to get GPU settings
2569 Views 12 Replies 4 Participants Last post by  aryuautku
I had GPU settings on XP(OC,clocks,Fan setts. etc) but this one doesnt have them.How to get it?
1 - 13 of 13 Posts
Go to the Guru3d site and download rivatuner
You need Rivatuner to control your GPU clocks, work fans and check out temps...
You mean the nVidia Control Panel?
In Vista it should be an item in the right-click menu over the desktop..
Also, you could get nTune for the nVidia Control Panel. I know it had clock and fan settings in XP but I've not used it or know if it supports Vista.
Thats why im asking,Rivatuner creates problems in GTA IV and i am trying to find a fan controller.
I use atitool as OC tool and i configured it to startup and use my sig rig OC.All i need is a fan controller
Yeah in the panel i had GPU settings.
Even better lol
Hmm its probably not rivatuner causing the problem, whats happening?
If you would have made all that clear in the OP we wouldn't have recommended Rivatuner to begin with...Well we probably would have anyway...lol
Good luck though...
What ive heard is the game is real buggy so i doubt its rivatuner.
Its not the heat,i lowered my OC and i could play gta 4 longer but with my sig OC i could play stable 4-5 hours with rivatuner and i can still play crysis even in MP without any crash-freeze 6-7 hours(no lifing FTW)
Sounds like the game is crashing, if it crashes to the desktop that's happening to alot of people right now.
The game wasnt givin these errors before...
1 - 13 of 13 Posts
