Convert MKV With subs to Dvd With Ease?
884 Views 8 Replies 6 Participants Last post by  Murderous Moppet
I have some Movies That have subtitles and i've tried converting with ConvertxtoDVD and the subs dont show on the finished work. Is there any program out there that coverts Mkvs with the subs?
1 - 9 of 9 Posts
Install www.cccp-project.net. Find the DirectVobSub config from the CCCP start menu shortcut folder. Make sure it's set to always load subtitles. Then, use any program which uses DirectShow to convert (if DirectVobSub doesn't show in the tray when playing the video, then it doesn't use DirectShow). Most software uses DirectShow.
coma thats crap software, use WinAVI 9 or convert x, also use Mkv toolnix to remove and edit subs
That's your entire argument? "It's crap software"?
I can't tell if you're serious or not...
ConvertXtoDVD would be ideal for the job. It can handle virtually any video format and insert subs.
Try reading the first post.
ConvertX will NOT insert hard subtitles, you have to turn them on when you're watching the film. That's what its always done to me at least.
1 - 9 of 9 Posts
