Cool water cooling project
356 Views 8 Replies 4 Participants Last post by  MartaLualdi
i found an old car radiator which i will use to replace a stock radiator in a water cooling set
i found it about 15 minutes ago so i could not take any pics
What do you think? good or bad idea if it is or not fell free to tell me
1 - 9 of 9 Posts
Exactly HOW old are we talking here? o.o
i think it is about a month or two
well in that case its probably aluminium =[
it is aluminum
ahh then it wont exactly play nice with copper components in a standard wc setup unless u get aluminium blocks
it is aluminum
make sure you put a few drop of an anti-corrosion additive otherwise it probably corrode and leak in about 20 years
If you get aluminum blocks as stated above, go for it but be sure to do anti corrosion additives. If you get copper blocks...eh...I wouldn't...
1 - 9 of 9 Posts
