I built my system just last month in January. Its only been a month and the coolant in the reservoir keeps emptying up every week. I refill the reservoir but in just a week the coolant reaches 3/4 from the top and starts making this hisss sound and I have to refill it. The sound is like a turbo in a car engine when the turbo kicks in it makes this hisss noise. This has the same hiss noise maybe it could be just air since its empty.
I have the CPU overclocked to 4.7ghzs and running my graphics card in the same loop. I don't run the PC 24/7 I run it for 12 hours then turn it off at night. I usually just play FPS games and GTA plus some video editing. Though I don't see any visible leaks anywhere and I was wondering if it normal for the coolant to empty this fast every week. If there is a problem please let me know the steps I should take to fix this issue thanks.
CPU: Intel Core i7 3930K @ 4.7ghzs
Mobo: Asus Rampage IV Extreme
GPU: GTX 680
RAM: 16 gigs Dominator Ram
Case: NZXT Switch 810
Pump: STORM D5 VARIO 8-24V Pump
Rese: XSPC 5.25" Bay Reservoir for single Laing D5
RAD: XSPS RX360
Tube: XSPC Flextube 3/8 - 5/8
Fitt: Bitspower 3/8 - 5/8
Block: XSPC Raystorm
GPU Block: XSPC Razor GTX680
GPU: GTX 680
RAD: XSPS RX360
