Coolbits 'Optimum'
1218 Views 24 Replies 11 Participants Last post by  lightsource
The magic button in Coolbits: "Detect Optimal Frequencies"... What exactly does it do? I know it finds a balance between Core speed and Memory speed, but I know that I can increase both slightly more then 'Optimum'. Is it like... on a car, a power graph has a peak,so the maximum power isn't at the highest RPM, it's at a certain RPM? Does OC'ing have a peak performance..?
OK, It's not very clear, but I'm trying here.
Lets say an increase of 50MHz on clock speed has a 25% Increase on Performance (rough figures here guys lol). That's 25% for 50MHz. Say if you pushed it a bit more, to say 60 Mhz, would there be less performance gain? (I mean, more performance, but less bang for buck)
Thanks guys, I've just been wondering.
1 - 20 of 25 Posts
· Premium Member
I can't remember exactly but I think its optimal for idle or something, but thats usually not the case. You can most likely go higher and still recieve better preformance. There is a certain point where increasing the clocks won't help to a phase were increasing the clocks hurt. The optimal is a good place to start, try going from there until your game stable =)
Thanks man, I've been fiddleing quite a bit with it, found a nice area with good performance, but what should I look out for to find any signs of damaging settings?
· Premium Member
Artifacting. If you get little shapes that are not the color they are supposed to be, then lower the clocks about 5-10 MHz and try again.
Reactions: Kahuna513
Thanks. I understand now, before... Damage from OCing was like being run over by a bus... "It happens to other people, but won't happen to me", but now I know what to look out for.
· Premium Member
From what I've read, the 7800 series are not great overclockers (like they need it), but you should be able to up it 10MHz past the optimum for the core, and about 30 for the mem. My optimum was 565/1000, and i'm 10/150 past that on my 6600GT.
Well considering the stock for a 7800GT is I think 420MHz and I can get mine to 500 I'd say it's pretty damn good at OC'ing, pretty much a GTX in disguise
but Kahuna, pretty much the Optimal Frequencies is the easiest way to OC that card and know you wont get any artifacts at least with mine I dont get any artifacts
· Premium Member
Set it high as you can...run the test...benchmark....
if it freezes...lower 5mhz....test...benchmark...until you see no artifacts and your scores start to level out....
I know with my 5700...if I clock it too high I get lower scores...
no overclocking is very much linear, if you get a 10% gain on 50mhz over you'll get a 20% gain on 100mhz over (unless you start screwing with timings etc, but assuming everything stays the same (all external variables, including heat) except the frequency of the gpu/ram)
· Premium Member
Well, I recently learned this when I couldn't overclock my memory more than 5MHz over than what I got in Detect Optimal frequencies. The core clock is dependant on memory clock; "How do you know this?" you say, well it overclocked my memory to 534 and my core clock was 341, I was using ATi Tool and I overclocked my core all the way to 415 (max allowed for the card) and didn't get any artifacts and still don't but if I go to 540MHz I can't even get no artifacts for less than 10 seconds.
Discussion Starter · #16 ·
Thanks a lot guys, didn't expect that much of a response lol.
Thanks again, it's all a lot clearer now, before OC'ing was a 'Mysterious Art' known only by you guys and possibly Ninjas... Heat is a problem, especially with stock cooling. I've got the air flow sorted, but really need to look in to a new HSF. Would that 'unlock' higher clockspeeds? Or just make performance better at current clock speeds? I understand the whole Temperature affecting Resistance thing perfectly, but would higher clock speeds be attainable?
I know that Japanese guys and Toms have got a P4 up to 5Ghz with extreme cooling, but I can't see how the cooling would make the 'Test' feature work better.
Basically, does the temperature affect the 'Test' feature on Coolbits?
just because you're memory was the bottlneck, also on some ati card's the atitool artifact scanner doesn't work properly but if you run a game you'll definately notice it.
If you care to know, the nvidia coolbits "detect optimal frequencies" runs on an algorithm dependant on heat and rendering accuracy, when it detects either too much heat being produced, or a loss in rendering accuracy (artifacts or otherwise) then it'll back down 5mhz and stay there. If your card is cooler, there is less resistance, better conductivity, and therefore you can almost always attain a higher clockspeed than without.
btw the 5ghz was nothing compared to some 8ghz overclocks they have running without having to fill up a tube with liquid nitrogen (using phase-shift cooling instead).
· Premium Member
Heat is major factor on any kind of overclock, but also beware that all cards will overclock differantly, better cooling, ram sinks for the memory, and good air flow in the case.
1 - 20 of 25 Posts
