1 - 3 of 3 Posts
Senior Overclocker
check out this pic
it will fit, don't worry
I'm not sure you will have a lot of wiggle room inside the case. My guess is they should fit, but it'll be tight. In the event that they don't, it's also possible to mount the fans on the outside/top of the case and add a fan guard.
1 - 3 of 3 Posts
