Greetings,
This message is for CM690 users.
I would like to know if it is possible to mount a Watercooling radiator inside this case, without any mod.
The radiator I would like to mount is either a blackice stealth 240mm or the new stealth 280mm. Their width is around 35mm if I remember.
Moreover, is it possible to mount 120mm fans or 140mm fans under to top hood (between the top plastic cage and the case structure)?
