1 - 15 of 15 Posts
I have a Cooler Master 690 Mid-size case, EVGA 780i FTW mobo, and a GTX 260 core 216 55nm video card (later to run 2 in SLI). What are my options for a water cooled system that can handle all this, fit in my case, and run 2 of these cards later in SLI?
thanks for any help,
Young 3D
I would like to be able to cool most of it if not ALL of it. I think that's possible isn't it?
Anyways, I know there is some great for sale stuff here on OCN, I just don't know what is best seeing as I'm a very new when it comes to water cooling.
What is a good system that will work for me?
here is my suggestion for the setup
Pump-----------Laing DDC 3.2 pump
Reservoir------- XSPC Premium Acrylic Reservoir LaingDDC
Tubing----------masterkleer 1/2 ID, 3/4OD
Coolant---------Distilled water- Feser view UV blue dye-PT nuke
Radiator--------- Black ice GTX 360
CPU block--------Swiftech Apogee GTZ Extreme Performance Waterblock
fans------------- panaflo high speed 3fans
Well if you wanna cool your cpu and eventually 2 GTX 260's I would recommend a MCR320QP or a Black Ice Xtreme GTX 360 rad. It will require some modding to fit that rad inside however. I wouldn't cool your northbridge or southbridge. If they get too hot then just get an aftermarket heatsink for them.
Discussion Starter · #6 ·
would the system listed above by 006 be able to cool my CPU, 2 260's and the northbridge and southbridge?
Also, where's a good website to get ALL of this stuff. Newegg doesn't have half of it. I'd like to do it all in one order if possible.
southbridge is not worth watercooling, because it hardly gets that hot.
EDIT: websites for water cooling gear:www.petrastechshop.com
www.sidewindercomputers.com
www.jab-tech.com
Discussion Starter · #11 ·
ok, so with this system:
I should be good to go?
right now, with my 6600 at 3.5 Ghz my temps are idling at 45*C and maxing around 70*C when testing with prime 95.
what temps will I be looking at with this setup?
-15*c of your current temps.
and also for the fittings get these http://www.petrastechshop.com/dadepofbofig.html
do you have a side window for your case?
How many of those connectors will I need?
and no, I don't have a side window, but its in the works hopefully.
i was asking about the side window because if don't have it you won't be needing the UV dye but just distilled water & PT nuke will work fine. and you will be needing 6 of those connectors for CPU only loop.
NOTE: take the measurements before you buy anything, do this so you know where and how will everything fit in or outside the case.
1 - 15 of 15 Posts
