http://www.coolermaster.com/product.php?product_id=6792The COSMOS II Ultra Tower features a streamlined design accentuated by a pair of distinctive handles like no other. The smooth, brushed aluminum touch of the side panels unlock and swing open like the doors of a luxurious race-car.
Hidden behind the front slide cover lies a stack of hot-swappable drive bays. The black interiors provide enough space for oversized XL-ATX System Boards equipped with 4 double width graphics accelerators. A second slide cover on top hides the Advanced Control Panel to manage up to 10 fans and their respective LED lights. The combination of its elegant looks, numerous expansion options and features make the COSMOS II a "Dream Case".
Welcome to the Cooler Master Cosmos 2 Club thread! If you are about to own this case , just post in here with proof and you'll be added to the list. If you have pictures of your case once you receive it then go ahead and post those as well.
DO NOT PM ME TO BE ADDED! Post in the thread and you will be added thanks!
https://docs.google.com/spreadsheet/pub?hl=en_US&hl=en_US&key=0Ar6kTG53l1i6dHJrWndzVlZqa2JGNEROU1JHbzItcHc&output=html&widget=true++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
- Stylish and streamlined race-car inspired design
- Brushed aluminum and steel for strength and elegance
- Airflow Optimized Design
- Supports up to 10 fans and 13 HDDs (2 from X-dock)
- Supports 4 Way SLI/CF
- Supports XL-ATX / SSI CEB / SSI EEB boards
- Advanced Control Panel includes 4 channel fan speed control
- Rich I/O support: USB 3.0 x 2, USB 2.0 x 4, e-SATA x 1, Audio In and Out
Available Color | Midnight Black |
Material | Exterior: Aluminum, Mesh, Synthetics; Interior: Steel-Alloy, Synthetics, Rubber |
Dimension (W / H / D) | 344 x 704 x 664 mm / 13.5 x 27.7 x 26.1 inch |
Weight | 22 kg / 48.5 lb |
M/B Type | Micro-ATX, ATX, E-ATX, XL-ATX, SSI CEB, SSI EEB |
5.25" Drive Bay | 3 |
3.5" Drive Bay | 13 (2 from X-docking with key locks, 5 HDDs in the Middle cage, 6 HDDs in the bottom cage) |
I/O Panel | USB 3.0 x 2, USB 2.0 x 4, e-SATA x 1, Audio In and Out |
Expansion Slots | 10+1 |
Cooling System | Front: 200mm LED fan x 1, 700 RPM, 19 dBA(converted from 120/140mm x 1) Top: 120mm black fan x 1, 1200 RPM, 17 dBA (200mm fan x 1 / 140mm fan x 2 / 120mm fan x 3) Rear: 140mm fan x 1, 1200 RPM, 19 dBA Side: 120mm fan x 2 (optional) HDD: Mid.HDD: 120x25mm fan x 1 (optional); Bottom HDD: 120mm fan x 2, 1200 RPM, 17 dBA |
Power Supply | ATX PS2 / EPS 12V (optional) |
2.5"/3.5"- SATA HDD Drive Bay | 11 (converted from 3.5" cages) |
Maximum Compatibility | CPU cooler height: 190mm / 7.48 inch VGA card length: 385mm / 15.15 inch |
For the sig tag see here:
http://www.overclock.net/t/1199098/cooler-master-cosmos-2-club/2740_20#post_17689936
