Cooler Master Elite 110
CPU: Intel Core i7-4770K
CPU Cooler: NZXT Kraken x40
Thermal Compound: Coollaboratory Liquid Ultra Thermal Interface Material
Thermal Compound: Xigmatek Freezing Point G4718 4g Thermal Paste
Motherboard: Asus Maximus VI Impact
Memory: Kingston HyperX Beast 2400 16GB (2x8) @ 1600
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk
Video Card: Asus GTX 760 DirectCUII
Case: Cooler Master Elite 110 ITX Case
Case Fan: Noctua NF-S12A PWM 120mm Fan
Power Supply: Cooler Master Silent Pro M2 620W 80 PLUS Bronze Certified ATX12V Power Supply
http://pcpartpicker.com/user/Liquor/saved/2TDl <--- will update this at a later time to reflect final build.
Pics coming...
Ran this guy up yesterday. Compared to the Cooler Master Elite 130 Case build everything is the same but the AOI Fan config, CPU cooler, and video card.
SWTOR max settings and video card settings maxed I get a steady 66-70 FPS @ 2560x1440 60Hz on the Qnix Korean IPS. I can do 120Hz but the game isn't seeing it for some reason. Whereas on the EVGA GTX780ti SC SWTOR does do 110 Hz.
I have not taken the lid off the 4770K and still using the Antec KUHLER H2O 920. but the Kraken goes in today with the delid 4770K.
The Asus GTX760 DirectCUII does fit in this case. though I had to install the mobo first then the card. connect all cables before installing the cooler. due to the ram and PSU connections, I can not run push pull fans. just a pusher or puller. currently in push setup but will route the Kraken so its between the front bezle and case front panel with a puller fan inside.
Cooler Master Elite 110 Case temps compared to the Cooler Master Elite 130 are very similar. GPU running 2560x1440 60Hz at 80C and 90% load. CPU is 33-5C idle and 43-45C under load. this is with SWTOR running. I have not ran any benchmarks on this system yet. I'm happy with the performance and size of this rig. The EVGA GTX780ti SC in the Cooler Master Elite 130 the temps are 30-32C idle, 40-42C under load at 2560x1440 110 Hz with the GPU running at 70C. The AIO cooler is in push pull config. Note the radiator fan setup, GPU's and the Cases are the only differences between the builds.
Everything is stock timings. Ram is unstable at 2400 but will adjust timings to get 2400 when I do the CPU and GPU overclocks. Working on cooling first.
Crysis 2 and Crysis 3 benchmarks will be done over the weekend.
Pics coming...
