This is the Cooler Master Elite M-ITX Case Owners club, the Elite M-ITX series includes;
- An ultra slim chassis accommodates both micro-ATX and mini-ITX motherboards
- Multi-device support
- Excellently cooled slim enclosure to support up to 65W CPU
- Passive mini-ITX case with silent constructional design
- Flex ATX 150W with Active PFC included
- Front I/O panel for easy access (including USB 2.0 x 2 and HD audio)
- ProClockers: Cooler Master Elite 100 Review
Air
Water
Please let us know if you are using a cooler that is not listed here, thank you.
Water
- The mini-ITX case with front mesh panel and vents on the top and side panels for better airflow
- One 120mm fan in the front (included) and Two 80mm fan on the side (optional)
- Dual Super Speed USB 3.0
- Supports a 120mm radiator in the front
- Supports standard length ATX PSU up to 180mm
- Supports graphic card length up to 210mm
- Ample storage - up to 3 HDDs / 4 SSDs
Air
Water
Water
- Unprecedented airflow for a Mini-ITX case
- 1/3 the size of a standard case
- Supports standard length ATX PSUs with innovative rear mount
- Supports ultra high-end VGA's (HD7990/GTX690)
- Stylish aluminum front panel
- USB 3.0 Super Speed Support
- Features a full Size 5.25" drive bay
- Supports up to 3 x 3.5" / 4 x 2.5" HDD/SSD (converted from two 3.5" HDD bays)
- AnandTech: Cooler Master Elite 120 Advanced Review
Air
Water
Water
- According to a Cooler Master rep the front panel from a Elite 130 can be fitted to an Elite 120 Advanced: Link
Air
Water
Water
- Only the front and lid of the white revision are in fact white, the internal frame is the exact same frame used in the standard black revision.
- Unprecedented airflow for a Mini-ITX case with front mesh panel and vents on the top and side panels
- Supports ultra high-end graphics card up to 343mm / 13.5 inch, such as AMD HD7990 and NVIDIA GTX690
- Ample storage - up to 1 ODD / 3 HDDs / 5 SSDs
- bit-tech: Cooler Master Elite 130 Review
Air
Water
Corsair H80 (HuwSharpe)
Cooler Master Seidon 120m (rizmo)
Water
- Some images feature a grommet above the PCI slots at the rear of the case, this seems to have been a development idea that was not introduced to the final product.
To join the owners club simply post a photo of your Elite M-ITX case and request "ADD ME" stating the name of your build.
- Elite 130 - HuwSharpe: ENCOM Recon
- Elite 130 - jonralf: Nice Tiny Rig (NTR)
- Elite 130 - Kriss941: AN602 - Thermonuclear
- Elite 130 - AwdDude: DevilRig
- Elite 120 - Kurokidan: Karasu-mini
- Elite 120 - Marcos Viegas: Mini Box
- Elite 110 - Liquored: Elite 110
- Elite 110 - schubaltz: Fragbox
- Elite 110 - Ndfeb: PartyBox
NOTICE: Please refrain from posting large photos and use thumbnails instead and if quoting a post please use the spoiler feature. Thank you.
