Hi equilni!Cats knocked over my Nano S, so for the time being, I had to revert back to my Elite 130.
Specs:
i7 4790S
Zotac GTZ 1070 Founders Edition
Alphacool XT45 120mm radiator
Bitspower 40mm Reservoir
Topsflo TDC-B pump
Heatkiller IV Acetal CPU & GPU blocks
EKWB fittings.
The drawing of the proposed loop.
http://www.overclock.net/photopost/data/1515617/4/47/4752ff64_IMG_0807.jpeg
Before the leak testing.
http://www.overclock.net/photopost/data/1515617/9/95/95822050_IMG_0811.jpeg
Ready to start... I know the cable mgmt could be better...
http://www.overclock.net/photopost/data/1515617/c/cb/cb84d794_IMG_0813.jpeg
http://www.overclock.net/photopost/data/1515617/a/ab/ab03506f_IMG_0814.jpeg
What kind of computer would necessitate a 8700k but no GPU?Hey guys, thinking of getting CM Elite 110 with i7-8700K but not sure what cooler to put inside and it to be quite. I don't plan to OC. Also, I will not use VGA but integrated graphics.
Suggestions?
Maybe something like Artic cooling freezer 120? Not sure how thick radiator can be..
What about PSU, should I go with SFX to have as much space as possible? (again, quiet is important).
The one that is running a lot of simulation/database/applications but not playing gamesWhat kind of computer would necessitate a 8700k but no GPU?
Right but wouldnt a ryzen 2700x be a better idea for that sort of workload then? Cheaper, less heat more cores etc. As for cooler id go with a 120 aio in the front.The one that is running a lot of simulation/database/applications but not playing games![]()
But I need integrated graphics.Right but wouldnt a ryzen 2700x be a better idea for that sort of workload then? Cheaper, less heat more cores etc. As for cooler id go with a 120 aio in the front.
You could buy a gt 710 on ebay for 5 bucks for a display output. Just saying 8700k's are super hot even at stock unless you delid them, and the ryzen 2700x would likely be faster for the sort of things you are doing....and its cheaper.But I need integrated graphics.
I guess I will go with artic cooling liquid freezed 120. It's almsot 50% cheaper then corsair H80i. Also, I will go with SFX PSU so there will be more space for cables and airflow.
Umm to get display port on an itx motherboard you are going to have to spend at minimum 140 dollars. I think the gt 1030 and ryzen route is the better option even if its a few bucks more, less heat output and it will be faster for what you are doing. Just my 2c. BTW i own a 8700k but only because i game at high refresh rates, if i didnt i would have picked 2700x over it.I need both display port and HDMI (use 2 monitors, UHD and QHD) and ryzen's price is same in my country like 8700K.
GT710 doesn't have hdmi and DP, I would have to go with 1030 (80€+ in europe with shipping), but I already have small case so GPU will take some space :/
No the gt 1030 is a 25 or 35w GPU it produces no heat. I dont own the elite 110 but im pretty sure a tiny gt 1030 would be fine with a radiator, maybe someone else can chime in tho. You could also consider finding a 1700x on sale, that would be even less heat and would still outperform a stock 8700k in programs that use cores properly.I was planing to buy MBO with z370 itx (190$ here) while AM4 B350 ITX is 135$. GPU would also make more heat in case right?
I am not sure if I put GPU, how much space for radiator I would have. Maybe I would need to go wit different case then..
You would have to look at your individual programs, but generally a 2700x is going to stomp a 8700k in programs that can fully make use of all of its cores. 8700k sells because its the best gaming CPU, productivity AMD has increased its lead with ryzen 2. As for heat ya its kind of a problem, with a 240 aio my stock 8700k was hitting the 80's in stress tests, depending on how stressful your programs are i cant say for sure that a 120 aio would be enough. Feel free to ask around in the 8700k thread but that is why i think amd is the better choice for a small form factor build that isnt gaming focused.Is the heat really that big of a problem for nonOC 8700K with 120mm thick radiator?
When I look at userbenchmark:
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-8700K-vs-AMD-Ryzen-7-1700X/3937vs3915
8700K beats almost everything^^
Agreed I'm already in the process of upgrading my box to a 2700x. Im going to see if I cant squeeze the Cryorig C1 into the case since Im using a SFX PSU. But the Temps and power are much more controllable with AMD's Ryzen CPUs.You would have to look at your individual programs, but generally a 2700x is going to stomp a 8700k in programs that can fully make use of all of its cores. 8700k sells because its the best gaming CPU, productivity AMD has increased its lead with ryzen 2. As for heat ya its kind of a problem, with a 240 aio my stock 8700k was hitting the 80's in stress tests, depending on how stressful your programs are i cant say for sure that a 120 aio would be enough. Feel free to ask around in the 8700k thread but that is why i think amd is the better choice for a small form factor build that isnt gaming focused.
You would melt down a 2700x with that cooler lol.Agreed I'm already in the process of upgrading my box to a 2700x. Im going to see if I cant squeeze the Cryorig C1 into the case since Im using a SFX PSU. But the Temps and power are much more controllable with AMD's Ryzen CPUs.
Already have it running with the c1 had to mod the bracket for it to fit. The c1 is massive and easily cools the 2700x I'm also running it with a overclock.You would melt down a 2700x with that cooler lol.
