Hey guys,
So i just build a new system wil the Cooler master haf xm.
Now... what i want to do is upgrade the air cooling on it.
Problem is... i do not know that much about fans.
So these are the specs of the case http://www.coolermaster.com/product/Detail/case/mid-tower/haf-xm.html
Now...i see there i can mount 2x 120 mm fans on the HDD cage... but it says 120x25... uhmm dose that mean i have to find specific fans and not all 120 mm will fit ?
What fans to buy ? some people say static pressure is most important in a fan... what is the specification that indicates this static pressure ?
Or should i just use high CFW fans ? ... Noctua ? Corsair ? and witch fans and why ?..... i know i ask alot of questions
That is because i want to understand more about fans.
What would you do to upgrade the air cooling of this case ?
