1 - 15 of 15 Posts
Hey all !!
Well, I've been looking forward to a new system build and here I have it but still, somethings not good enough......
So, money is a VERY big problem here in M'sia cuz the price of computer parts are mostly kinda bumped up and right now, I hasn't been any good.......and I only have a roughly 1200 bucks since I started saving for the past few year.
2 Months ago....
To start with, I went to a local shop at a heritage island...you can guess XD....and grabbed a Silent Pro M600 , CM V8 and a WD Caviar Black 1TB HDD
A few days later........
Since I got another piggyback to the shop with my friends and bought the remaining parts which is the
-ASUS Maximus III Formula
-Intel Core I5-760
-Corsair 4GB DDR3
-ASUS GTX 460 TOP 1GB
-ASUS SATA 24x DRW-24B1ST
After the parts came, I start with putting up a system test bench until........
3 Weeks ago
I finally got my HAF 922 along with 4 CM Sickle Fans RED one's and I start to plan the design......
Anyways, here's my plan, from first to last
-Rip open the case and spray paint it black , inside out.
- Spray the Front bezel mesh with black yellow color
- Paint the hazard warning stripes on both the side panel
- Spray paint the front body armor with black and later on with glossy paint .
- Use body filler ( 3 cans of them ) to make body armor in the top intake/out take fan
-draw republic of gamers decal on paper, cut it out and use to spray paint a logo onto the case side panel.
-sanding the top armor( not shown )
-spray paint the top body armor with glossy paint first and then black
-bend the cpu retention hole to a larger one cuz I don't have dremer sold here
-make a shield for the cpu cooler.
- put in every parts I have
Discussion Starter · #2 ·
so here it goes:
Sorry to say but I don't have much time on day 1 so just some pics.........
Here it is, the case is now completely painted black
second coating.....
and the side panel too
Looking good here......
Hey, I'm modding my own HAF 922 as well and I too spray painted the inside of it. One thing you want to make sure though is that you spray your case evenly. It's a good idea you did multiple coats, but it looks like you oversprayed in some areas. This is common for even regular painters to do when you see a spot that's not 100% covered on the first coat, it kind of bugs you. However, as long as you spray lightly and evenly, you'll be okay. I learned this the hard way lol.
Also, are you putting any clear coat on after you spray paint? Your paint may chip when you start putting components on it or even the side panels if you don't. Not trying to be harsh or anything, just giving some pointers.
Good luck though, I like your idea! Subbed
Thanks for the tip man, how ever, I too did a few more coats after cuz my cam went out of battery so I couldn't have the chance to take a pic of it .......
Since that I woke up pretty early today so I decided to continue with my work log
Day 2........
Quite a sunny day here....
I know, it's my dog looking after the backyard
So, I draw those hazard markings on a piece of A4 paper and it eventually look pretty nice .....
So here is the side panel.....
And the markings on it........
With some yellow paint........
Tadaa.........very nice eh?
Now how does that look in a close range?
:D
So here are the finished looks....
Right side panel.........
and left side panel....
Coffee break
Nah......it's orange
Back to work
So my mind went off with the decals.........and instead cutting it out on a piece of paper........
The ROG decal......
Drew it on a paper which is exactly the same as it
Successfully managed to cut it out
Another comparison
Success !!!
Discussion Starter · #6 ·
Day 3
Long school hours right now..........Anyways, I went to the shop and bought 3 bottle of body fillers.........not bondo cuz they don't sell em'
Looks similar to anyone?
Still...........Trying to think of something to do with em'
Be back with more pics:eek:
So, I finally figured out what to do with the body filler and here's how it goes
To anyone with this design on the group, hope you guys won't mind:eek:
Hmm..... first stage didn't went well
Those body filler seems to be congesting the bezel until I popped them out....Quite nasty before washing:p
How it looks like after sanding with 80 grid sand paper
more pics..
more...
Argh!!! cracks!!! looks like I'll have to do something........
Anyways, I sprayed it with clear paint, if I can fill those holes...
Here's how it turns out....
Not bad eh?
That's all for today, hopefully I'l be able to finish it tomorrow and sorry for the blurry pics, only have a 3Mp digi cam..
Discussion Starter · #13 ·
Originally Posted by Hbliss23;12142446
That is sickkkkk. Congrats on the job well done. Now you've made me wanna go out and mod my Antec 900.
Thanks
And good luck with your mod
1 - 15 of 15 Posts
