1 - 1 of 1 Posts
Cooler Master N200 - Mini Tower Computer Case with Fully Meshed Front Panel and mATX/Mini-ITX Support
Description:
The N200 is the first case in Cooler Masters brand new N Series - compact mainstream computer cases with extensive water cooling support and improved air cooling performance wrapped in subtle and simplistic designs. The N200 not only supports 120mm radiators along the back, but is the first mini tower that supports installation of a 120mm or even a 240mm radiator in the front of the case! Thanks to a full mesh front panel, 2 high quality Cooler Master XtraFlo fans and large air vents, N200 boasts excellent cooling performance. Despite its extremely compact size, the N200 supports 160mm tall CPU air coolers, long high-end graphics cards, including the upcoming AMD Radeon HD 7990, four 2.5-Inch SSDs and three 3.5-Inch HDDs.
Details:
DetailValue
BindingPersonal Computers
BrandCooler Master
EAN0884102023026
FeatureEdgy, asymmetrical design with full mesh front panel
Mini tower with great expandability that supports up to three 3.5" HDDs and four 2.5" SSDs
Supports a 240mm liquid CPU water cooling kit in the front of the case
Supports high-end graphics cards with a length of up to 355mm (14 inches)
Supports CPU air coolers with heights up to 160mm (6.3 inches)
Removable dust filter under the power supply mount area for easy maintenance
Supports SuperSpeed USB 3.0
LabelCoolermaster
ManufacturerCoolermaster
ModelNSE-200-KKN1-AMZ
PublisherCoolermaster
StudioCoolermaster
TitleCooler Master N200 - Mini Tower Computer Case with Fully Meshed Front Panel and mATX/Mini-ITX Support
UPC884102023026
CatalogNumberList - CatalogNumberListElementNSE-200-KKN1-AMZ
Item Height14.9 inches
Item Length17.5 inches
Item Width7.9 inches
Package Height9.8 inches
Package Length20.1 inches
Package Weight11.35 pounds
Package Width16.9 inches
PackageQuantity1
ProductGroupPersonal Computer
ProductTypeNameSYSTEM_CABINET
UPCList - UPCListElement884102023026
Item Weight9.5 pounds
1 - 1 of 1 Posts
