1 - 4 of 4 Posts
Still a GPU Aficionado
For any interested, the V8 has pretty good reviews so I figured I'd post this.
http://www.cmstore-usa.com/v8-nickel-plated-copper-base-aluminum-fins-8-heatpipes-cpu-cooler-refurbished/
EDIT: Heres a few reviews
http://www.legitreviews.com/article/833/1/
http://www.kitguru.net/components/cooling/zardon/cooler-master-v8-cooler-review-revisited/
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/17444-cooler-master-v8-cpu-cooler-review.html
Specifications
Model RR-UV8-XBU1-GP
CPU Socket
Intel Socket:
Sandy Bridge 1155
LGA1366 / LGA1156 / LGA775 *
AMD Socket:
AM3 / AM2+ / AM2
CPU Support
Intel:
Core™ i7 Extreme / Core™ i7 / Core™ i5 / Core™ i3 / Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium / Celeron
AMD:
Phenom™ II X4 / Phenom™ II X3 / Phenom™ II X2 / Phenom™ X4 / Phenom™ X3 / Athlon™ II X4 / Athlon™ II X3 / Athlon™ II X2 / Athlon™ X2 / Athlon™ / Sempron™
Dimension 120 x 128 x 161.1mm
Weight 1.91 lbs
Heat Sink Dimensions 120 x 120 x 158mm
Heat Sink Material Copper Base / Aluminum Fins / 8 Heat Pipes
Heat Pipes Dimensions 6mm
Fan Dimension (W / H / D) 120 x 120 x 25mm
Fan Speed 800 - 1800RPM
Fan Airflow 69.69CFM
Air pressure (mmH2O) 2.94mm H2O
Bearing Type Rifle Bearing
Fan Life Expectancy 40,000hrs
Fan Noise Level (dB-A) 17 - 21dBA
Fan Speed Adjustment Install on PCI Slot
Connector 4-pin
Fan Control PWM + VR Controller
Rated Voltage 12V
Start Voltage 7V
Operating Voltage 10.38V - 13.2V
Rated Current 0.12A
Input Power 1.44W
Warranty 90 Days
Shipping would be ~$12 for me in Ohio, if anyone is wondering. Kinda kills the deal, half the cost of the item.
The fan is mounted to that black piece, so it's not simply something you can leave off (which I was hoping for), that thing is so ugly.
Yeah, i'm not a huge fan of the looks or the red LED, but its a great price even with shipping. My buddy uses one and its one of the best air coolers. I was able to oc his 2700k to 4.8 and his max temp was 76C very impressive.
1 - 4 of 4 Posts
