Cooler Master Seidon 240M RL-S24M-24PK-R1 240mm High Performance All in One Liquid/Water CPU Cooler
Description:
The Seidon 240M is Cooler Master's latest, incredibly compact water cooling kit that aims to bring water cooling to the masses. It comes factory filled, sealed, and tested with a two year zero maintenance guarantee. The high performance 240mm radiator was designed to dissipate extreme heat from overclocked CPUs. Thanks to two 120mm PWM fans with wide RPM ranges, Seidon can operate silently, or unleash a powerful cooling storm at your command.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Cooler Master |
EAN | 0884102020049 |
Feature | Pre-filled with coolant at the factory then sealed and pressure tested, allowing a two year zero maintenance guarantee Waterblock made with ultrafine micro channel to enlarge the contact surface between cold plate and coolant Durable and powerful water pump dissipates heat effectively and maintains temperatures through stable water circulation High performance 240mm radiator designed to handle high wattage overclocked CPUs Double 120mm PWM fans with wide RPM ranges to fine tune and balance fan noise and performance Compatible CPU Sockets - Intel LGA 2011, 1366, 1156, 1155, 1150, 775 and AMD FM1, FM2, AM3+, AM3, AM2+, AM2 |
Label | Cooler Master |
Manufacturer | Cooler Master |
Model | RL-S24M-24PK-R1 |
MPN | RL-S24M-24PK-R1 |
Publisher | Cooler Master |
Studio | Cooler Master |
Title | Cooler Master Seidon 240M - Liquid CPU Water Cooling Kit with Pre-filled Coolant and Copper Heatsink |
UPC | 884102020049 |
CatalogNumberList - CatalogNumberListElement | RL-S24M-24PK-R1 U281-RL-S24M-24PK-R1 |
Item Height | 1.1 inches |
Item Length | 10.7 inches |
Item Width | 4.7 inches |
Package Height | 5.6 inches |
Package Length | 13 inches |
Package Weight | 3.75 pounds |
Package Width | 10.8 inches |
PackageQuantity | 1 |
PartNumber | RL-S24M-24PK-R1 |
ProductGroup | Personal Computer |
ProductTypeName | COMPUTER_COOLING_DEVICE |
UPCList - UPCListElement | 884102020049 |
Item Weight | 2.1 pounds |
