1 - 6 of 6 Posts
the loudest part of my computer atm is the power supply. i have corsair tx850...really annoying..so im looking for something "better".
is it worth buying Cooler Master Silent Pro Hybrid 850W PSU? or something else..
· Premium Member
Originally Posted by DizZz View Post
what components are you running? you might not need an 850w and there are some other really good options but knowing what you run would be helpful so i can suggest some alternatives for you
This; if you have components that don't take up too much power, SeaSonic's fanless PSUs (up to 520W) and Rosewill's Silentnight 500W are truly quiet.
Which means, you can run an i7-3770K with a GTX 680 and still be fine with one of the mentioned above.
1 - 6 of 6 Posts
