I'm installing my Corsair H70 today, was wondering if I can get some input about this_
Now the only location I can attach the radiator is the rear 120mm fan location_
I was thinking of setting it up to Intake air from the back but this might cause temps inside the Case to heat up dramatically_
If I set it up as Exhaust(Pulling air inside the case out, I would decrease case temps but yet at the same time warm air will be going through the Radiator due to my MSi GTX560 Ti video card that dumps all the hot air inside the case. (This would result in poor CPU Cooling performance)
How do you guys have your H70 installed? Are your temps better with the Intake Install or Exhaust install? Or there was no difference for you?
