The Cooler Master RR-V6GT-22PK-R1 V6 GT Multi-Socket CPU Cooler follows in the footsteps of the revolutionary V8 and V10 CPU coolers from Cooler Master. Designed with a muscular engine look, the Cooler Master RR-V6GT-22PK-R1 V6 GT Multi-Socket CPU Cooler fits nicely with any performance hardware. The Cooler Master RR-V6GT-22PK-R1 V6 GT Multi-Socket CPU Cooler also features new mechanical structure that includes: V-shaped heatpipe array, asymmetrical aluminum fins (which are densely stacked for optimal cooling), two 120mm silent fans with PWM speed control function and DynaLoop long life technology, snap-on cover to conveniently replace fan if needed.
What It Is And Why You Need It:
Densely stacked asymmetrical tilted aluminum fins for muscle cooling performance.
"Double-V" heatpipe array helps spread out the six heatpipes to fully utilize the cooling fins on the cooler. It also allows airflow to reach each individual heatpipe as opposed to traditional coolers.
Accelerating twin high-speed PWM fans with tool-free fan boxes deliver invincible cooling capability.
Engine oil cap controls the LED strip with color changing function.
DynaLoop™ Bearing Fan: Innovated self-lubricating bearing mechanism decreases oil-loss commonly seen on sleeve bearing fans. Evolutionary wave blade fan provides tremendous airflow with steady pressure.
Snap-on cover to conveniently add a second fan if needed.
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=6514354&CatId=493
