1 - 1 of 1 Posts
Super Moderator
Cooler Master V8 GTS Cooling Fan RR-V8VC-16PR-R1
Description:
The V8 GTS is the latest addition to Cooler Master's popular V-Series high performance CPU coolers. V8 GTS sports a newly designed, powerful car engine look. Cooler Master's new high performance horizontal vapor chamber technology found inside the V8 GTS spreads heat up to 8x faster than traditional heat pipes, minimizing CPU hotspots and quickly balances the heat load between all heat pipes. The combination of the horizontal vapor chamber, 8 heat pipes, and aluminum fins allow the V8 GTS to display extremely high efficiency and cooling performance.
Details:
DetailValue
BindingPersonal Computers
BrandCooler Master
EAN0884102021039
FeatureCooler Master's all-new Horizontal Vapor Chamber technology minimizes CPU hotspots and spreads heat evenly to all heat pipes
Triple Tower Heat sink with 8 High Performance Heat pipes maximizes cooling performance
Dual High Airflow PWM fans with Red LEDs for an aggressive look
Fan speed and noise can be fine tuned and customized for desired balance between performance and sound
Fans feature Cooler Master's 4th Generation Polyoxymethylene (POM) Bearing for increased longevity (up to 160,000 hours) and is dustproof
Compatible AMD CPU/APU Sockets: FM2, FM1, AM3+, AM3, AM2+, AM2
Compatible Intel CPU Sockets: LGA 2011, 1366, 1156, 1155, 1150, 775
Universal Mounting System is compatible with most Intel and AMD CPUs
LabelCooler Master
ManufacturerCooler Master
ModelRR-V8VC-16PR-R1
PublisherCooler Master
StudioCooler Master
TitleCooler Master V8 GTS Cooling Fan RR-V8VC-16PR-R1
UPC884102021039
CatalogNumberList - CatalogNumberListElementRR-V8VC-16PR-R1
Item Height6.1 inches
Item Length6.6 inches
Item Width5.9 inches
Package Height1 inches
Package Length1 inches
Package Weight1 pounds
Package Width1 inches
ProductGroupPersonal Computer
ProductTypeNameCOMPUTER_COOLING_DEVICE
UPCList - UPCListElement884102021039
Item Weight3.1 pounds
1 - 1 of 1 Posts
