I'm curious what you guys would appraise this PSU for. It's in fine working and aesthetic condition. The only flaw with the PSU is the cable sleeving on the 24 pin atx power has been torn.
Specs:
Model: RP-600-PCAR (Non-PFC)
Type: ATX from factor 12V V2.01
Input Voltage: 90~132V / 180~260 V (Selectable)
Input Current: [email protected] / [email protected]
Input Frequency Range: 47~63Hz
Fan: Sleeve bearing 120mm fan
Power Good Signal: 100-500ms
Hold Up Time: >17ms
Efficiency: >70% typically
MTBF: >100,000 hrs
Protection: OVP / OPP / Short Circuit Protection
Dimension: Standard ATX PS2 150 x 140 x 86 mm
Operation Temperature: 5~50 C
Safety: Safety Nemko / TUV / cUL / CE / BSMI / FCC / CCC
UPC Code: RP-600-PCAR
Originally Posted by Penicilyn
$35 as they're pretty cheap to begin with and I know mine was loud as hell.
no doubt, that's kinda what I was thinking about pricewise. Perhaps I can find someone with a farm that needs an extra PSU and wouldn't mind the noise. I replaced a 430W CM psu with the 600... and I'm replacing this one now with a 520HX to reduce on cable clutter in a smaller coolermaster 330 case.
