I really, really like this case. Why? First off it looks Military in a simple, functional Black Stealthy way. It has Steel and Mesh.
It buids on the weakness of the 120 being shorter and getting rid of the welded in hard drive cage. It is also built for water cooling in the front and has plenty of built in storage. I love the CoolerMaster haf Xb and this is like a mini travel version. What is missing from almost all mini itx cases in this class is a 5.25 cage. Why is this important? Not for optical but to add a fan controller, or led controller etc. That is what is going to set my case off. I am going to add a military style fan controller with toggles on the front. It will also have built in Leds to make this like a Special Forces type of look and authentic. I am going for a completely clean install of mil spec components.
1. Corsair Vengeance Dominator 2x8 1866
1. Crucial 480 ssd
1. Msi Gtx 770 mil spec video card
1. Msi mini Itx mil spec board z87
1. Seasonic Gold 660 modular
1. commanche military fan controller
1. not sure I am going to go water cooling or air.
I also plan to take out the side mounted hard drive cage
This is going to be a superclean build with cable management and only using the minimum cables needed with the modular power supply.
Also aim is to get as fast a boot time as possible using Windows 8
1. Crucial 480 ssd
