CoolerMaster HAF 932 + bay resevoir
393 Views 2 Replies 2 Participants Last post by  Chaz351
I am configuring a water cooling system for my HAF 932. I want to use a 5 1/4 Bay resevoir filling the resevoir using the fill hole that is located on the top of the case. However, I cannot find one that can accomodate 1/2" tubing with a g 1/4 fitting. Any thoughts?
Chaz351
1 - 3 of 3 Posts
Thank. I thought I had mentioned that the fill hole on my HAF 932 is on the left side of the case and the the fill holes on resevoirs I am looking at are either in the center or right hand side. I would probably add a couple of extra inches of hose so I can pop out the resevoir for filling, but if I did not need to I would rather not.
1 - 3 of 3 Posts
