Coolermaster hyper 212 reviews
373 Views 4 Replies 4 Participants Last post by  hawaiian_geek
how good is the coolermaster hyper 212's performance
what idle and max load temps can i get with a dual fan seting
1 - 5 of 5 Posts
The vigor gaming Monsoon III is a hyper 212 with a plastic shroud and two fans. It depends on what fans you buy but you can see how it stacks up against other competition. For your specific temps, nobody is going to be able to guess accurate temps.
i just want an average
thanks anyway
I use a CM Hyper 212 with a push/pull configuration using the CM stock fan and a Scythe S-Flex "F" fan. It's used with a Q9550 cpu that's overclocked to 3.6ghz load temps are in the 34c - 36c.
1 - 5 of 5 Posts
