1 - 20 of 30 Posts
Efficiencycionado
and the price is huge too.
but it's also like a ram cooler as well.
i'm still wondering how does it cool. especially with that tec thing.
It's honestly not that great. Get a TRUE or Noctua for a lot less money.
Efficiencycionado
yeah, my rig is getting a true. i'd rather upgrade my cpu if i were to buy that thing.
Efficiencycionado
well, if it's only priced the same as the v8, why not?
its exactly double the price of a V8 which i wouldnt buy either.
V8 = $70
V10 = $140
Both from newegg. Ignore them both and get a TRUE.
Originally Posted by gamer11200 View Post
Arctic Cooling Freezer is amazing. Quick install and good price and gives good temps when coupled with OCZ Freeze
It's decent for socket 775 chips, but it would completely fail at cooling an i7 chip.
Discussion Starter · #13 ·
They don't make a version for an i7? I thought that they did,
My bad, I got it confused with 160WATT 775 cooling ability of Freezer Xtreme http://www.canadacomputers.com/index...648&cid=FN.349
They do make a i7 bracket, that's the reason why they came out at the same time as the i7 chips.
Honestly, the V10 is too much money, for what a TRUE can do, Yes you can cool RAM too, But I can buy a $15 Corsair Dominiator RAM cooler, and still be cheaper than $140
You're right, I thought you were talking about the freezer 7 pro
have you guys seen how much a TRUE costs with a 1366 bracket... add 2 fans... now the price comparison between a v10 and a TRUE isnt so bad... i run cooler than a TRUE and i'm g2g out of the box, a TRUE you have to lap, use washer mod, add 2 fans, not to mention it's ugly as hell... I'll chose my V10 any day of the week!
Efficiencycionado
so what are the temps?
They should've made it without the TEC, it doesn't seem like the TEC helped much. It probably could be less than $100 without the TEC.
1 - 20 of 30 Posts
