There is passive cooling on all mosfets. Their temps depend upon the airflow and the air from your cpu hs/f. If your worried just add a spot cool. I heard that most Gigabyte boards run cooler than their competitors though.
Originally Posted by Robilar ![]() The Gigabyte EP-45 UD3P http://www.motherboards.org/reviews/...ds/1829_1.html |
Originally Posted by Penicilyn ![]() The DFI boards are known for running quite cool This is the 750SB one so you can overclock that 9850BE really nicely DFI LP DK 790FXB-M2RSH http://www.newegg.com/Product/Produc...82E16813136057 |
Originally Posted by Bouncer ![]() Gigabyte comparable and cheaper? http://www.newegg.com/Product/Produc...2E16813128352R |
