Cooling: Dual Fans
898 Views 9 Replies 7 Participants Last post by  sonicmat
Stock fan: 51c Idle / 66c Load
Dual 80mm Fans: 43c / 55 - 56c Load
What I used:
- Black Tape (Hold the fans together)
- Crazy Glue the fans on the heatsink on the side (Easy to remove)
The Crazy Glue
1 - 10 of 10 Posts
Oh, don't worry. I taped mine on. It's just for testing purposes. ...
Right Unknownm?
Right Unknownm?
mine ha no way man. I'm leaving this on because my temps have gone way down
You could bust out a drill with metal bits and drill some holes for zip ties in the HS or the PCB... that would hold up for sure.
That looks pretty mean though!
I would hate to see that soundcard die a horrible fan blade stricken death when the glue corrodes!
it won't be falling down. After I took those pictures I used a tool to grip on just the fans and made it hang for over a hour. It didn't even come lose
Go for more, I hit 850 core on mine (unstable though)
I run 1050 mem stable though
Looks good, id do it but even with my stock cooling and 2 12cm fans my pc is too noisy for my likings.
1 - 10 of 10 Posts
