Cooling Questions
541 8
curreently my CPU Temp is at 45 °C (113 °F) my Motherboard 40 °C (104 °F),this is with 2 Case fans runnin at 2711rpm my cpu fan at 3444rpm , is it adviseable to overclock a little? or shud i get better cooling? any idea wot i shud do?
1 - 9 of 9 Posts
i think u should be able to OC a little, but you dont wanna go over temps of 50c. it would be a great idea to get a better cpu cooler, but unless u wanna OC alot...u might be ok, depending on how fast the temps will rise.
and is 45C idle or under load?
hmmm thats wierd, cuz it usally goes up 5 deg or more unless u have water cooling. but i guess u can go up a little, you just dont want to go above 50-53.
but if u wanna OC more i recomend a better cooler
1 - 9 of 9 Posts
