1 - 5 of 5 Posts
I'm trying to cool down my fx5700le and it would be my first time going custom. All I have is a small little 40mm fan over the core and it runs stable at 300/430, but once I get it to go very high (375ish) it pretty much dies after playing BF2. I'm thinking of getting small heatsinks for each of the ram things on the card and then get a larger heatsink and a 40mm+ fan on top of the core. Any tips on doing this so that it all works properly?
Discussion Starter #2
Some tips like what is the best heatsinks and how to put the stuff on. I know you use thermal paste, that artic silver 5 sounds good, along with that other artic silver stuff. What do you think would be the best cooler (not water cooling - too expensive for me right now) for oc'in a fx5700le?
yeah AS5 is best inbetween metal and chips, but somethign that works great too is silicone
, so pretty much try and gets as much air over the card as you can to keep the temps down
1 - 5 of 5 Posts
