1 - 4 of 4 Posts
How do you guys keep your laptops cool or at least not hot? My brother's laptop heats up like crazy. When I used Speedfan, the temps were crazy some were in the 50s, 60s, and the remote something was 79C. I ordered one of the stands with two fans on the bottom to place the laptop on. Anything else can be done?
That's not too hot for a lappy... <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br>
What is he doing that it heats up so much? The Lapcool you ordered will help a bit, but I don't see other solutions
I just got a Yate Loon pad on ebay for about $15 shipped. And that is all you really can do for laptops. They are meant to be run hot, I suggest you get the program called Notebook Hardware Control 2.0. This program will allow you to adjust the Mhz on the laptop. So when using the battery I use the "Max Battery" profile and this underclocks my comp to as low as 600mhz and keeps it very cool. While when I a plugged in I use "Dynamic Switching" which will change the multi depending on processor use. This in all keep its running very cool. I in the past would hit 70C on this think but now barely hit 60C and eve now get to mid 50C with the chill pad.<br><br>
pink
Yeah that's not too hot. My friends was getting in the 85C range while gaming and I think they are usually rated for 100C+. Just keep the fan intake open to fresh air and don't worry about it. Remember if it blows up just send it back since it's the manufacturers fault, not yours.
1 - 4 of 4 Posts
