1 - 3 of 3 Posts
ive been playing about with my processor and ocing it and so far ive been able to get it upto 3.52ghz which is a 3.2ghz stock but running only stock cooling it was over heating and restarting my machine.
i want to get a decent cooling system so i can oc it and keep it like that running stable so could anyone suggest some good cooling kits or processor fans?
ive found this but would like your opinions on it
http://www.savastore.com/productinfo...id=44&rstrat=0
is it worth getting and will it help cool my system down enough? also found the big tycoon fan but only able to find it on US sites, any UK ones about selling it?
thanks
richard
if your gonna get a water cooling kit, try a thermaltake bigwater se or one of the swiftech kits
but if you have the time and money, you could always do some custom water cooling, custom usually performs better vs. kits
1 - 3 of 3 Posts
