coolit eco alc
325 Views 1 Reply 2 Participants Last post by  AgentHydra
i have a coolmaster elite 430 case with the two top mount fans installed but with this new coolit eco alc cooler it cannot fit in the rear mount becasue of those fans which i do not want to remove (beacause of asthetics )but is it possible to de-attach the cooling tubes and mount the fan and radiator out side the case then re attach the tubes or will this void the warranty and if not is there any other good water cooled recommedations
1 - 2 of 2 Posts
Yea disassembling it will definitely void the warranty lol.
Have you tried putting the rad in both ways? (with tubes coming out the top or the bottom)
Also you could try mounting it to the top of the case, that way you can keep both of the top 120mm fans.
1 - 2 of 2 Posts
