Specs:
GA UD5 x79
3930k
32gb Gskill 1600
GTX 680
1000W Silent pro
So for some reason my main bios is corrupted (not pressed in with green light on I believe). When I try to boot, it just sounds like there's a shortage, then after 3 times it finally boots up, makes you think it's entering bios, then resets and does it all over again.
When I press the dual BIOS button in (blue light) it works and everything is fine.
This makes no sense because I flashed both BIOS sides to F12.
I read somewhere to hold ALT + F10 to copy settings over, but that was to copy Main Bios to Back Up bios, so the guy had it wrong:
http://forum.giga-byte.co.uk/index.php?topic=13030.0
I tried to CMOS reset, but my rig is so damn bulky my Graphics card and Noctua D14 are in the way.
Again, my backup is working just fine
Anyway around this?
Thanks!
GA UD5 x79
3930k
32gb Gskill 1600
GTX 680
1000W Silent pro
Anyway around this?
Thanks!
