1 - 15 of 15 Posts
this is my second build and well before i buy im looking for a little feedback about all the parts...<img alt="" class="inlineimg" src="/images/smilies/proof.gif" style="border:0px solid;" title="Proof"> and if i should keep my current build because im selling that to buy this. "in my sig"<br>
im still a novice in most of this but i learn as i go /for lack of better words so your input will be vary helpfull<img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2"><br>
thanks to all your input:<br><br><br>
Mobo: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2366176&sku=M452-2646" target="_blank">http://www.tigerdirect.com/applicati...&sku=M452-2646</a><br><br>
CPU: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2341479&sku=CP1-DUO-E6300" target="_blank">http://www.tigerdirect.com/applicati...=CP1-DUO-E6300</a><br><br>
Tower & Power: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2485587&sku=TC3J-2191" target="_blank">http://www.tigerdirect.com/applicati...&sku=TC3J-2191</a><br><br>
HDD: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2268595&sku=TSD-320AS" target="_blank">http://www.tigerdirect.com/applicati...&sku=TSD-320AS</a><br><br>
Memory: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1950080&sku=O261-8034" target="_blank">http://www.tigerdirect.com/applicati...&sku=O261-8034</a><br><br>
Graphics: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2512219&sku=E145-7912" target="_blank">http://www.tigerdirect.com/applicati...&sku=E145-7912</a><br><br>
CD Drive: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1827330&sku=L12-1090" target="_blank">http://www.tigerdirect.com/applicati...0&sku=L12-1090</a><br><br>
OP system: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=335878&sku=M17-7500" target="_blank">http://www.tigerdirect.com/applicati...8&sku=M17-7500</a><br><br>
Cooling: <a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1020396&sku=K450-1018" target="_blank">http://www.tigerdirect.com/applicati...&sku=K450-1018</a> not shure if it will work with chipset.?<br><br>
ALL IN ALL IT WILL COME OUT TO around $1,300 but thats not that bad<br>
I WILL be overclocking my CPU into the 3.0GHz's
Ok, my suggestions:<br><ul><li>MoBo: <a href="http://www.newegg.com/product/product.asp?item=N82E16813128012" target="_blank">GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965</a> $146.99</li>
<li>CPU: <a href="http://www.newegg.com/product/product.asp?item=N82E16819115005" target="_blank">Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775</a> $180.00</li>
<li>RAM: <a href="http://www.newegg.com/product/product.asp?item=N82E16820231065" target="_blank">G.SKILL 2GB (2 x 1GB) DDR2 800 (PC2 6400)</a> $314.00</li>
<li>Video: <a href="http://www.newegg.com/product/product.asp?item=N82E16814130065" target="_blank">eVGA 512-P2-N573-AR Geforce 7900GTO 512MB GDDR3</a> $259.99</li>
<li>HDD: <a href="http://www.newegg.com/product/product.asp?item=N82E16822148144" target="_blank">Seagate Barracuda 7200.10 250GB</a> $79.99</li>
<li>DVD: <a href="http://www.newegg.com/product/product.asp?item=N82E16827106019" target="_blank">LITE-ON 16X DVD±R DVD Burner W/ LightScribe</a> $30.99</li>
<li>PSU: <a href="http://www.newegg.com/product/product.asp?item=N82E16817341001" target="_blank">OCZ GameXStream OCZ600GXSSLI ATX12V 600W</a> $119.99</li>
<li>Case: <a href="http://www.newegg.com/product/product.asp?item=N82E16811119094" target="_blank">Cooler Master Centurion 532 RC-532-SKN1 Black Aluminum bezel</a> $69.99</li>
<li>OS: <a href="http://www.newegg.com/product/product.asp?item=N82E16832116056" target="_blank">Microsoft Windows XP Home With SP2B</a> $87.99</li>
<li>CPU Cooler: <a href="http://www.newegg.com/product/product.asp?item=N82E16835185027" target="_blank">Scythe SCINF-1000 120mm CPU Cooling Fan/Heatsink</a> $57.99</li>
</ul>
Total: $1,347.92<br><br><br>
Notes:
<ul><li>Since you don't have SLI/Crossfire, I selected an Intel 965 Express based board. Better overclocker, esp. with the E6300, and cheaper</li>
<li>That water cooling unit likely won't cool good at all. Either invest in good watercooling, or just get a high-end air cooler, like the one I suggested (Noctua is good also, but can't find it in stock)</li>
<li>The GameXStream is a lot better than the Ultra. Nuff' said</li>
<li>I picked the somewhat smaller version of the Seagate to save some</li>
<li>And where do the savings end up? In 2GB DDR2 800 G.Skill RAM. More than worth it.</li>
</ul>
I would have to agree with Chozart. If your getting a Core 2 duo setup, u need at least 2gb of ram and that gskill is really good for overclocking.
Reactions: death25
I'd say keep the NUUO he currently has, and upgrade the motherboard to a Kentsfield supporting board (ie, P5B-Deluxe) or the MSI board he posted.<br><br>
or<br><br>
Use the money to spend on a watercooling setup, 160 bucks (120 from PSU and 60 from the Ninja) can get you someting nice.<br><br>
or<br><br>
Get the E6600 with that extra cash.<br><br>
Good Job Chozart (as always!)
Reactions: death25
The NUUO is a little weak for my taste for a highly overclocked Core 2 Duo rig (only 30A max load on the 12V rails).<br><br>
Good suggestions though Wowza... stuff to think about <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Reactions: death25
Discussion Starter #6
that looks like a great choice but now i need to sell my current comp for that price "unlikly" suggest any places to advertise? <br />
on a second note that was the first time iv put a comp together on my own, did i go in the right direction or was i off? and iv noticed that my mobo's northbridge get burning hot , should i worry?<br />
thanks<br />
<br />
<br />
Subtotal: $1,347.92 <br />
Tax: $94.35 <br />
$36.75 UPS 2nd Day<br />
Total: $1,479.02<br />
<br />
i hate jersey, taxes are a *****. can i get these all from a diff site
Try ZipZoomFly. Their site is a little hard to navigate, but the prices are ok, and on most items free shipping.
I quickly ran the whole list through ZipZoomFly, with a few changes (They don't have G.Skill for example)<br />
<br />
MoBo: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=322342" target="_blank">Gigabyte GA-965P-DS3 P965 Express</a> $148.99 <br />
CPU: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80858" target="_blank">Intel® Core 2 Duo E6300 Conroe Processor 1.86GHz</a> $183.00 <br />
RAM: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85025-6" target="_blank">Corsair TWIN2X2048-6400C4 2GB Kit DDR2-800 XMS2-6400 CAS4</a> $299.00<br />
Video: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=322835" target="_blank">eVGA GeForce 7900 GTO PCI Express 512MB GDDR3</a> $259.99 <br />
HDD: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101464" target="_blank">Seagate Barracuda 7200.10 250GB Serial ATA (3.0Gb/s) 7200RPM</a> $85.00<br />
DVD: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=170677" target="_blank">Liteon SHM-165H6S 16X Dual Layer DVD±RW Drive w/LightScribe</a> $38.99<br />
PSU: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=316504" target="_blank">OCZ OCZ600GXSSLI GameXStream 600W</a> $112.99<br />
Case: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=141778" target="_blank">Coolermaster RC-532-SKN1 Centurion 532 Mid Tower</a> $79.99<br />
OS: <a href="http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=604614" target="_blank">Microsoft Windows XP Home Edition (Full Version) OEM</a> $89.99<br />
<br />
$1,297.94 and Free Shipping! Digging up the cooler somewhere else<br />
<br />
CPU Cooler: <a href="http://www.frozencpu.com/products/5088/cpu-scy-09/Scythe_Infinity_10-Heat_Pipe_CPU_Cooler_-_AM2_Ready_SCINF-1000.html?tl=g40c14s52" target="_blank">Scythe Infinity 10-Heat Pipe CPU Cooler</a> $57.99<br />
<br />
Total $1,355.73 + shipping for the cooler (or just find another cooler on ZipZoomFly)
Discussion Starter #9
thxs<br />
true, it is hard to get around but the shipping is a nice touch<br />
<br />
is this ok, HDD was on back order so is this one ok: 100713-6 Maxtor DiamondMax 10 6V200E0 200GB Serial ATA (3.0Gb/s) 7200RPM Hard Drive w/8MB Buffer<br />
<br />
and the cooler...<br />
<br />
Zalman CNPS9500 LED CPU Cooler
I'm sure that NUO would handle that rig just fine.
Discussion Starter #11
but im looking to sell my current computer to buy this better one that we are talking about
Discussion Starter #12
O and the total is a nice $1339.92 -if i had a little extra cash i could 2nd day deliver it still for less then wut newegg would charge me in tax,<br />
<br />
and were can i sell my comp :tried e-bay"<br />
this whole project is grounded untill i sell my current...
Discussion Starter #13
ok well iv found a possible buyer for my comp but im a little stand offish due to how the message readout, here it is/ wuta you think:<br><br>
"Dear Seller I saw the placement of this item, am much interested in buying it for my client becuase is urgently needed in my store for the urgent need by the customer... I want to know the perfect condition of this item i will be very happy if you can allow me to purchase it right away.... and i will like to make the payment through BANK OF AMERICA MONEY... if this is okay by you kindly get back to me with the total price of this item including your details and i will handle the shipping with my fedex account. Looking foward to read from you."
Well, he might not be fluent in English, which would explain the way he expresses his thoughts <img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)">
Discussion Starter #15
true, and if this does go good i need a final say: is this new rig going to be alot better and will it be worth selling this current one to buy it. thanks, thius final say will seal the fate of my build...
1 - 15 of 15 Posts
