Core 2 Duo E6400 multi.
336 Views 4 Replies 4 Participants Last post by  ckp64
Whats the max multi on the e6400?
1 - 5 of 5 Posts
seriously, its stuck at 8? which core 2' go over 8.
On most boards all the C2Ds are unlocked downward to a minimum of 6. The only C2D that is unlocked both up and down are the X6800s. For the E6400 the max multi is 8 and 1 less or 1 more for every model upward or downward (IE: E6300 has a 7 max multi)
The E6600 has a stock max multi of 9X (266x9=2.4ghz) and the E6700 has 10X (266x10=2.66ghz). And the X6800 is fully unlocked (downwards and upwards) so those 3 have a multi over 10.
1 - 5 of 5 Posts
