1 - 9 of 9 Posts
· Premium Member
Originally Posted by xNiNELiVES View Post
As the title says which gives better performance?
core clock over memory clock. if your planning on overclocking work on the core first.
However, the 600 series is seriously crippled at mem too which is why at stock it loses to 580 as an example. Raising MEM will of course fix that issue so it's give and take.. I wouldn't concentrate simply on core but try and get the MEM to around +450 to +500 with whatever core you can put there also.
Just my opinion though.
So you're saying that a 580 beats a 680 both at stock? You're totally high bro.
I wish but seriously, no that's not what I'm saying. The 680 beats 580 yes of course (ie: graphics test), but it will lose in combined test so it's not beating it outright as-is.
I've had single 580 and then SLI and I've had single 670 and then SLI so I know how they behave and how one destroys the other, no neither is a 680 but the difference (especially in MEM) between 670 and 680 is so little it's almost not worth mentioning.
· Premium Member
Ok well I'm at 1245 core and 3499 mem (7ghz)
nice, did you bench it with either heaven or 3dmark11?
· Banned
It depends on the architecture. Smaller memory bus' will give you good gains if you overclock the memory more. On tahiti, memory overclocking doesn't pay out as much as core overclocking because tahiti already comes with a blazing fast memory interface.
1 - 9 of 9 Posts
