1 - 13 of 13 Posts
hi
i have a Core i5 2500K with Asus sabretooth P67 motherboard
and OCZ Obsidian PC3-12800 ram
my idle temps at 1.6GHz per core are 27C
but when i run Prime95 de CPU will OC it self at 3.7GHz and i reach 60C
is this normal? and can the cpu handle this?
i am using a Corsair H50 cooler
i have tried reseating and replacing the kooling paste
it helped a bit got around 2/3C less
im going to do a push pull setup with the Corsair H50 kooler mabey thatll work?
any suggestions?
what temps should i normally get with Corsair H50 at 3.7GHz
60 C is way cool and your safe. you dont need to worry about your temp unless you cross 70 - 75 C at load.
you might hit these temperature at vcore of 1.27V at load (this is my guess)
you can easily clock to atlest 4.3 ghz with H50. higher than that your ambient temp depends a lot
i dont know it set to default
what should the vcore be then?
i just dissabled speed step it was ffin up windows 7
also i managed to do push pull with my Corsair H50 and its now at 58C at load
Discussion Starter · #6 ·
so 70C is a good operating temp?
damn dint know cpu's could handle that heat
i always tought that 60C was max go any higher and u damage the cpu...
so there is still room left to oc my 2500K?
i just looked up my Vcore and its at 1.312V
can i lower this?
if yes wouldent my temps go down drasticly?
70c is fine. Intel specs the maximum reccomended temp at 72,6C, but you're probably fine at up to 85c, as long as you don't run it 24/7 at that and don't go crazy on the vcore.
EDIT: Yeah, you can probably take it down a bit, I doubt you need 1,3vcore for 3,7Ghz. Try 1.22-1.25 or so and see if it's stable
ok i put vcore down to 1.250
and im having load temps of 55C now
guess thats a good thing
so in total i managed to go down 7C just using push pull and vcore + reseating the cooling paste
tCase isn't for the cores, it's for the IHS on the CPU. Add about another 20-25C onto that and you have the maximum safe operating temperature.
Intel set the Throttle Limit to 95C on Sandybridge for a reason; This reason specifically is to PREVENT damage before it occurs.
why dont you go to 4.5 ghz, nothing wrong anyway you paid for it.
and you should be able to get to 4.5 ghz around 1.28V - 1.35V at load
so try with 1.3 or 1.32V at load
i dont know about LLC (load line caliber), voltage drop at load in Sabretooth.
Enable medium load line - vdroop
and use vcore of 1.355. if its stable at boot and load then reduce voltage supplied (@BIOS)
1 - 13 of 13 Posts
