core i5 750 or core i7 920 ???
5460 Views 93 Replies 27 Participants Last post by  FSF-Foxhound
hello all...
I have a quick question regarding which one to get from these 2 processors: core i5 750 (2.66 GHz) or core i7 920 (2.66 GHz)?
I am confused since the 2 ones seem to be similar to each other except for that the core i5 has no HT, while the i7 does have, but on the other hand... the Core i5 memory controller 1333, while the Core i7 is only 1066, and not to mention that the Core i5 has the Turbo technology while the Core i7 has not.
so I need your help in this, I need to know:
1- which one of these 2 CPUs would be faster on stock speed.
2- which one would overclock higher?
3- both would be with at least 6 GB DDR3 so which one is best ?
for sure I am going to replace the board with some one that fits them and I think it is more likely to be the Asus P5p43td pro
so now what do you say please ???
which one.... which one ?
thank you all
1 - 20 of 94 Posts
IIRC, the main upsides of i7 are triple channel and HT. I've seen both i5s and i7s go up to 4GHz a lot, but I'd surmise from the number of 5GHz i7 clocks I've seen that the i7 is the one to go for for OCing.
From what I've heard the i5 actually beats the i7 in SOME categories, but by only a few % / points.
In memory intensive tasks the i7 will still prevail.
1. Clock for clock I think the i7 will still come on top
2. I haven't seen i5 clocks but I know most of the new i7s can get 4.0-4.5GHz with low volts.\\
EDIT: The board you said you will most likely get won't be compatible with either of those CPUs.
If you're on a budget think about this, a decent i7 board is $200++ while a decent i5 board is only <$200.
Gaming wise, go i5. If you need HT, go i7. I would save the money though and get the i5. Dual channel RAM is still a lot cheaper than tri-channel and so are the P55 motherboards. It all adds up.
i7 will be faster in environments that actually use the multi-threading. Otherwise they're prob. comparable. It depends what you're doing.
Either or.
It's a lot easier to help you decide which is best for you if you can describe the primary things you'll be using the machine for.
oops... it seems that the motherboard I mention is LGA 775, so forget it, I am going to concider another one.
so what about that i7 memory controller is only 1066, while i5 is 1333 ???
how much does that make difference ?
and how much the extra one memory channel makes difference over the core i5 that lacks it ?
The extra memory channel makes a good difference, a larger amount of bandwidth for sure.
It should be a little noticeable in tasks that need the extra memory band.
I am going to upgrade my PC to use it for intensive video stuff and intensive gaming
Depending on what you mean by 'intensive video stuff', I'd say go i7.
It makes no difference. Those are just the stock memory speeds for P55 vs X58. Both the i5 750 and i7 920 should have no trouble with memory rated at DDR3 2000+. You would of course have to set the speed in the BIOS.
Also just an FYI, the i7 920 does support Turbo Boost (and hence can use a 21x multi), but it isn't as high as it is on the i5 750. It becomes irrelevant when you factor in overclocking though.
In all honesty the extra memory channel on X58 won't make much, if any difference. The real benefit of X58 is the QPI and 36 PCI-e lanes vs 16 on P55.
here is the confusing point
that the i7 is 3 channels @ 1066, while the i5 is only 2 channels but @ 1333
does that mean that this way both CPUs are parallel in speed/performance ??
i7. They're both good CPUs but since you're into video encoding and stuff like that, then get an i7.
You're also more futureproof with the i7 as the i9 CPUs are going to be released on the 1366 socket, LGA 1156 is a dead end (unless Intel releases some kind of i6
So if you have the money for it, then go i7
and what about the turbo in i5 that's not available in i7 ?? how much difference does this make ?
i7 has a turbo mode aswell.
True but it should be noted, the i5 has a much more sophisticated turbo mode and increases much higher than the i7 for single threaded programs.
Ah okay, I wasn't aware of that
But I think the i7 would be the best choice, even if the turbo mode on the i5 is better.
+1. Though as neuro said, it depends on what you're definition of this really is. Specifically, will you spend enough time doing encoding etc. to justify the cost. Basically, how much will you actually 'use' the advantages of ht, & is that worth it. Only you can really answer this.
This is a very good point. While obviously the i9's will be quite expensive on release (& prob. for some time), they will go down eventually. The presence of an upgrade path is certainly something worth considering.
another question hasn't been answered yet? what about the difference the i5 is 1333 , while the i7 is still 1066... so what about this ???
1 - 20 of 94 Posts
