1 - 6 of 6 Posts
Just wanted a quick heads up on my OC and see what you guys think about temps and volts
Core i5 760
4013mhz
37C averge idle
65C average load
1.25v vcore (1.26v in asus utility on windows) llc enabled
1.1v qpi
1.5v mem @ 1600mhz
Is the above good? What do you think I could get out of my cpu safely?
any/all feedback welcome...
Its another tool like occt and prime95 in stressing your cpu to see if the oc is stable. I love occt for gpu testing but I primarily use prime95 for cpu's. I would say give it a 12hr overnight run and you should be good, buuut there's much debate on the time frame of these tests. Good luck!
1 - 6 of 6 Posts
