1 - 16 of 16 Posts
Just putting together my plans for my new build.
I know that the only difference is the the 2500k has 4 less threads than the 2600k.
My question is will i miss those 4 threads.
Rig is for gaming.
I guess you mean the i5 2500k vs the i7 2600k. If you overclock it to 4.5 Ghz or more you probably won't notice the difference gaming, although the 2600k is faster. You'll probably only see performance decreases if you are using sli or crossfire and you need an extremely fast cpu to avoid bottlenecking your gpu setup
It would still have to be a game that can utilize more than 4 threads. Even then, the difference won't make the game unplayable. That $100 would make a bigger difference if applied towards the GPU or an SSD. 2500K is already way overkill for gaming.
Well i am looking to tri sli 470s.
Would the i5 2500k be ok if i oc it alot?
Plus i would have anti virus stuff in the background.
But i have a fast ssd for my o/s.
an OCed 2500k is more than enough for that, throw the extra savings into something else like cooling
yup 100% agree if you are gaming just go for the 2500k then put the money saved towards your video cards or something else.
however if you are like me and encode videos pretty much every day those extra 4 threads are totally worth it.
in the end it comes down to what you do with your pc......or if you just want bragging rights
MegaTechPC
For epeen you gotta get that i7 yo!!
most cases 2500k is better value.. does well with games and even benching.. however if you have work or something integral to what you need to do with your system that will utilize more than 4c/4t then get the 2600k
Waiting for 7nm EUV
Rig is for gaming.
No, that is not the only difference. The i7 2600k has 8 MB of L3 cache, whereas the i5 2500k has 6 MB of L3 cache.
Having said that, there are games where the i7 2600k performs worse than the i5 2500k because of HT, in a few it is practically a tie and in others it wins. Only a test with HT off on the i7 2600k would clarify the importance of HT versus extra cache vs 100 Mhz extra stock clockspeed in the games it wins.
If yo want the best price / performance ratio, the i5 2500k is the best choice, it overclocks as well as the i7 2600k and it will handle three GTX470 in SLI just fine.
Initializing...
i5 2500k overclocks better from what I hear.
1 - 16 of 16 Posts
