How do you like the new look/thread's format?
  • It looks great!
    Votes: 31 91.2%
  • Nah, it's ok.
    Votes: 3 8.8%
  • It's horrible!
    Votes: 0 0.0%
21 - 40 of 2163 Posts
High as I can go while staying within VID specifications (1.375000 in bios).
4.000
20x200 @ 1.37500 vcore / 1.35 QPI / 1.84 PLL / 1.64 DRAM / HT Off
trigunflame is your loadline calibration on? just wondering because your vcore in cpuz is 1.376 and in your bios its 1.375. When I do loadline it actually drops a few volts 1.39v drops to 1.38v and with out LLC 1.39v is 1.36v.
Lurker
yea i know its weak for an extreme... and I have a question about temps since I'm new to this platform is 40 idle and 75 load too high? have pic of temps below
LLC is on; it will raise up to 1.376 like that at peak.
Load temp is a little high but anything under 80c or so is fine for 24/7 imo. With an unlocked multi you should try raising that if you can; didn't think 965s needed 1.4v to hit the 4-4.2 range; or did you just arbitrarily place it there?
Lurker
your right i forgot to take my voltage down ^^ i just put it there to get a quick 4ghz
Originally Posted by Acroma
Starting this thread for all the Intel Core i7 guys. I'll update daily.
Please post validation to get added to the list.
Also a system setup link to help others new to OC'n
Please add: Voltages, temps and speeds/ratios
Core i7 list.
List is in order of joining.
eflyguy Intel Core i7 Extreme 965 @4.24
killerhz Intel Core i7 920 @4.2
opt33 Intel Core i7 940 @4.8!
bulmung Intel Core i7 920 @4.0
List of Motherboard OC threads.
EVGA: EVGATech_JacobF's EVGA x58 guide
Please help me update, any good links will get you +rep
You are really making it hard for me to not wait to switch !
one hell of a max m8.
Thanks, just got a decent OCer, makes up for my E8400
na, but i still want your case
FYI almost broke 10k on geekbench
my wifes intel doesn't want to OC either. maby same batch?
