1 - 18 of 18 Posts
Well I have been with overclock.net for a while now and Im finally building my 2nd PC. My first I sold because I needed the money at the time. This build is going to be my best one yet. First ill give you a list of the components and why I chose each component. Please feel free to give any advice or additions or subtractions to my build.
Intel Core i7 920
http://www.newegg.com/Product/Produc...82E16819115202
I chose this cpu because of the performance it gives and because it can overclock like crazy...
Asus P6T Deluxe v2
http://www.newegg.com/Product/Produc...82E16813131365
I chose this motherboard because I have read a lot of reviews on it and saw a lot of high OCs using this mobo.
Antec 1200
http://www.newegg.com/Product/Produc...82E16811129043
I chose this case because of the reviews and because I owned the Antec 900 and most of the problems I had with the 900 are fixed with the 1200.
PC Power & Cooling S75QB 750W ATX12V
http://www.newegg.com/Product/Produc...82E16817703009
I chose this power supply because of the Huge 60A single rail and because I have previously owned an 610 silencer and loved it.
EVGA GTX285 1GB SC
http://www.newegg.com/Product/Produc...82E16814130446
The reviews on this card at resolutions at 1920x1200 just played everything at a near 60 fps. So why not
SAMSUNG 2343BWX High Glossy Black 23"
http://www.newegg.com/Product/Produc...82E16824001317
I was orginally going to go with an 24" but then i saw these monitors a little while ago and fell in love because how sexy they are
(UPDATED)
2x Western Digital Caviar SE16 WD3200KSRTL
http://www.newegg.com/Product/Produc...82E16822136039
Instead of the WD3200AAKS, ive decided to go with the KSRTL because I have previously owned the WD2500KS and loved it so why change? lol
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produc...82E16820227381
VS
Corsair Dominator 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produc...82E16820145224
Now if you have any suggestions or changes you would highly recomend or a really good CPU Cooler please let me know so I can add it to the build. Rep+ for constructive criticism.
thats a lot of money for a case , but i would definitely buy a faster hard drive (velociraptor). when your building a system like this dont go cheap on a hard drive ? you also need a good cpu cooler vendetta 2.
Reactions: BloodThirstyEmu
1 veociraptor or if you got money get 2 and let it flyyyyyyyyyyyy. the hd is going to be the slowest thing in your computer.
if you have the money id go with the x58 evga and some velociraptors for a raid 0 set up. The ram is good but Corsair dominator 1600 is always nice too
If you're going on air id go with the Thermalright extreme 120 1366 version, I've only heard great things about it.
Nice mobo, don't get the X58 from Evga, this mobo is way better, only Evga classified blows everything away
I should get a Coolermaster Haf 932 case myself, for the silence and WC options.
For power supply: PSU's from Corsair and Coolermaster are way better!
Originally Posted by BloodThirstyEmu
Hmm.. Velociraptors are pretty expensive, are they really worth there money? Are they that much faster?
yes , yes and yes.
like i said before dont go cheap on your hard drive. buy one velociraptor try it out if thats not fast enough then get a second. that was my plan, but i was happy with the speed i got with one velociraptor. DONT GO CHEAP MY FRIEND.
· Eh, Wha?
Only if you're doing tons of reads and writes (makes for slightly more efficient scratchdisk/pagefileing but you have 6gb of ram so I doubt you'll need that at all)
That drives kinda small though. Grab a TB caviar black for 3 times the storage at twice the cash, much better deal. You'll thank yourself later when you have the thing half full and would have had to buy another drive otherwise.
I say you water cool the thing, it'll just plain look (and obviously work) better. You get a cheap system together for the price you would spend on a high end motherboard torturing tower cooler anyway.
· Iconoclast
So should i go with 4x 320Gb in RAID 0 or 1 Velociraptor?
The velocirator is an incredible waste of money, even on a build like this.
Discussion Starter · #16 ·
Well, for right now ive decided to stick with 2x WD3200KSRTL. Once I save up more money ill get 2x 300GB Velociraptors. Now my problem is DDR3 RAM. Are the corsair dominator 3x2Gb 1600mhz worth the extra 70$ over the OCZ Platinum which also gets a 20 MIR also?
· Iconoclast
No.
1 - 18 of 18 Posts
