Originally Posted by Blameless
That liquid cooling kit will be woefully insufficent if you intend to seriously OC the CPU. Either fork over the money for some serious water cooling components, or get a decent air cooler.
Cool cool, I really didn't know which is why I came here
but yeah, I'll probably stick to air then. I don't know how much I'm actually going to push the processor, as I'm sure it'll be a huge upgrade right out of the box, but it is good to know it DOES have OC potential (from numerous reviews) and that when I get to it, it can handle it extremely well.
The only heatsink/fan option from the site is:
CPU Fan and Heatsink
Fan Speed:3200 RPM
Air Flow Rate:33.96 CFM
Wind Pressure:3.23 mmap
Rating Current:0.15A
Rating Voltage:12V
If that's inefficient, is it possible to take a heatsink/fan off of a processor once it's been applied? Or does that sound iffy considering it's an i7..
Going with the linked OCZ, although while the company does have it, and it's only $30 more, the specs on newegg are slightly different that the site's, notably the Cas Latency and the Timing:
OCZ-Platinum 6 GB [2 GB X3] DDR3-1600 Triple Memory Module
Type: 240-Pin DDR3 SDRAM
Speed: DDR3 1600 (PC3 12800)
Cas Latency: 7 (Newegg's is 8)
Timing: 7-7-7-24 (Newegg's is 8-8-8-24)
Volt: 1.65
Heat Spreader: Yes
And lastly, specs for the currect selected psu:
600 Watt -- Power Supply
Type: ATX12V Ver.2.2/EPS12V
-Ideal for Intel/AMD dual-core CPU
-NVIDIA® SLI™ READY
-ATI CrossFire Certified
-Dual +12V rails
-Active Power Factor Correction (PFC) Circuit
-Universal input with PFC- 90V to 264V
-Embedded thermal sensor
-Reliable 120mm ball-bearing fan w/Blue LED
-20+4-pin MB connector
-4 Pin +12V x 1
-8 Pin +12V x 1
-Peripheral power connector x 6
-Serial ATA connector x 2
-Floppy power connector x 2
-PCI Express connector x 2
-Easy-plug connector
-Sleeved cables
-UL, CSA, FCC
-Build-in protection against over-load, over-voltage, over-temperature, over-current and short-circuitry
-Automatic fan speed control to achieve optimum balance between effective cooling and acoustic noise
Again, any input is good input, I have a good month or so before I'm going to go ahead with an order. Do it once, do it right... right?
