Easy:
First, take the image you want to use and resize it to 125x125 pixels, save it as "oemlogo.bmp", and copy it to: C:\\Windows\\System32.
Next, open a notepad (Star Menu, All Programs, Accesssories, Notepad), and type the fallowing:
[General]
Manufacturer=
Model=
[Support Information]
Line 1=
Line 2=
Line 3=
Fill in the lines after the "equal" signs with whatever text you wish, and save it as "oeminfo.ini" in the same C:\\Windows\\System32.
Now, right-click My Computer, select properties, and check out your work!
