1 - 20 of 33 Posts
So there's some dust in the computer (i7 920), stock cooler, and when i encode some videos @ 50% CPU or when I play Left 4 Dead 2, it shows 100C...
Is this normal and/or too high ? Idle @ 55-60
When it was new, Idle was 35+... now 55-60. Can dust have that much effect on my temp ?
Thanks !
That is nuts...dust would have some effect but I wouldn't think it would almost double your temps. I would reapply thermal paste and see if that fixes your issue.
Dust can prevent air from cooling your heatsink so YES it can. Why haven't you invested in an aftermarket cooling system yet?
Dust on my laptop's heatsink raised the temps on it by an average of 35c.
Never, I bought the computer some months ago
The Newt in Overclock.net
I7s are extremely hot chips. Id get a cheap aftermarket cooler like the Dark Knight to keep it in check. Good flow and no dust build up are also essential to a healthy cpu.
100c is the thermal junction MAXIMUM the chip will start tjrottling at that point and can be damaged. For encoding and such, sub 70c would be a safe place to shoot for.
Clean out your case ASAP!!!
either buy some canned air-works okay.
or use an aircompressor to blast air thru your cpu cooler and blow the dust out of there! If you use an air compressor, make sure that its not blowing any condensation out of the nozzle. spray it at a piece of cardboard or paper first to see if any water comes out.
100c is the danger range and it should never get that hot
Some time ago when encoding i was getting 75.... but now 100...it's weird.
Laptop Enthusiast
Doubt it's that hot. Your machine would actually shut off if it got that high. There's a cut off switch in every Bios that will literally perform an emergency shutdown if temps get too high.
That sounds like a glitch but take a pic of your heatsink just to be sure.
Discussion Starter · #14 ·
Clean your computer!!!!!!!!!! Your heatsink is cloged and cannot perform its duties!
That is not some dust that is a massive accumulation of pc killing dust.do u smoke around tour computer? Have pets? Thats insane for a couple months. CLEAN IT!
Discussion Starter · #18 ·
well, you did ask, heyzeus
I know and i love it. I had a computer like that once. Bro just get some of the compressed air in a can and get all that **** out of there.
1 - 20 of 33 Posts
