1 - 8 of 8 Posts
I'm considering to sell off the old kit that I've got.
It's the 1866Mhz 7-8-7-20 kit.
I could just replace it with VENGEANCE kit (C9)
The old one at my place is worth about $300-400.
I'm on a very high OC of 4.3Ghz. & the ram gotto run at 9-9-9-24(1.65v)
I've been reading a bit & that Vengeance kit could preform better/the same.
Anyone got hands on experiance?
DOES IT WORTH TO CHANGE???
Thanking all for ur advice.
Do not sell that golden set of ram, you'll regret it.
They are also so hard to find.
Ver2.1? Hypers.
I have the same set.
Ver2.1? Hypers.
That's what I have in mind. It's a "golden batch". What the produce today won't even comes near to it. At least this we'll get to play with it...
After reading on Vengeance I'm starting to reconsider. Anyway I'll just play with it more to get the best out of it. 9-9-9-24 not at it's best, just safe. Getting it CL8 to see how.
What's ur timing & performance? Mind posting up ur CPU-Z?? mine is at below
· Premium Member
Replacing that dom gt kit with vengeance would be a drastic downgrade. Whoever said the vengeance would perform the same or better has no idea.
I have the same dom gt 1866 7-8-7 kit, they'll do 1600Mhz 6-6-6 18 easily, or 2000Mhz 8-8-8.
With some extra vdimm I've had them to this:
stable @ 7-8-7-2200?
· Premium Member
Maxxmem stable at least, voltages were pretty reasonable for the clocks but I don't go for max possible overclocks 24/7.
On the other end of frequency this is the same kit I was using in a competition for highest maxxmem score using a 2:6 memory divider:
1 - 8 of 8 Posts
