My rig was originally 2x7970 reference cards and have my case airflow setup to accompany the two blower type cards. My EVGA 780 with the ACX cooler will be coming on Monday, and I want to prep my case for when it gets here.
At the moment, only my top fan is exhaust while the side panel and front fans are intakes. I also have a 120mm fan inside the case right in front of the 7970 which is an intake.
The 780 will be throwing heat all around my case and with my current config, I am pretty much trapping the air inside unless all that air pressure is being exerted through the top exhaust because there's so much air, it'll be like a wind tunnel effect?
I was thinking of making my side fan exhaust, but I don't know what to do with the fan I have inside. If I put it as exhaust, to dissipate heat away from the GPU, it'll get trapped between the front intake.
Or, I can have the side fan as intake and both inside fan and front fans are exhaust?
Or, I don't even use a side panel fan because I only made it because my 7970s were ovens so I had to.
I know this card will run cool, but I just want to maximize case airflow if I am able to anyway.
Thanks.
Thanks.
